Morrigans Zero
Re: Morrigans Zero
Re: Morrigans Zero
Postby Paul » Thu Nov 08, 2012 1:29 pm
baby_astons wrote:I see I've found the airplane counterpart to my :shifty: aston modifications - wait 'till I get my hands on the stuka :laughing-rolling:
why didn't you shout, I'd have the fitting micro screws for the adjuster heads...
I'm currently out of stock of fitting adjectives so I'll just throw you a k morrigan!!!!!!!!!
You certainly have met your match BA, all great modelling ! :D :D
Re: Morrigans Zero
Postby baby_astons » Thu Nov 08, 2012 2:10 pm
hehe, yes morrigan and myself need to make a model of the flying car from the man with the golden gun -
I'll do the car and send to morrigan to do the flight relevant modifications :mrgreen:
Re: Morrigans Zero
Postby Paul » Thu Nov 08, 2012 2:19 pm
baby_astons wrote:hehe, yes morrigan and myself need to make a model of the flying car from the man with the golden gun -
Or Chiity ....????!!!! Oh yes that would be great !!!! :D :D
Re: Morrigans Zero
Postby morrigan » Thu Nov 08, 2012 7:29 pm
baby_astons wrote:one address for you morrigan, to see what you'd be looking for:
http://www.watchtool.co.uk/mini-stainle ... -7640.html
or here:
http://www.usmicroscrew.com/micro-screw-sizes.html
Thanks Baby-astons, thank goodness for watchmakers supplies!
Re: Morrigans Zero
Postby morrigan » Thu Nov 08, 2012 7:37 pm
Well the doing the flying bits for the Man with golden gun car looks quite do-able, using a cessna skymaster kit as the donor for the conversion.
Now look what you're done.......started ideas :laughing-rolling:
Now the trick would be to make Chitty a flying model - all that weight on those stumpy little wings and tiny little rotors! :think:
Re: Morrigans Zero
Postby baby_astons » Thu Nov 08, 2012 7:55 pm
...now need to look where to find this kit:
http://static.cargurus.com/images/site/ ... 57043.jpeg
:shifty:
Re: Morrigans Zero
Postby Paul » Fri Nov 09, 2012 1:14 pm
baby_astons wrote:...now need to look where to find this kit:
:shifty:
Hum, yes very possible with both your skills :D , though Chitty might be impossible re flying .......
Re: Morrigans Zero
Postby baby_astons » Fri Nov 09, 2012 5:11 pm
ONE flight is always possible - out of the window in the 10th floor... :mrgreen:
Re: Morrigans Zero
Postby morrigan » Fri Nov 09, 2012 7:54 pm
Well after seeing this, there is hope for a flying chitty!!!! :shock: :laughing-rolling:
http://www.youtube.com/watch?v=HMegAHTtJqY
Re: Morrigans Zero
Postby baby_astons » Fri Nov 09, 2012 8:03 pm
Re: Morrigans Zero
Postby morrigan » Fri Nov 09, 2012 9:13 pm
Now that would spin the neighbours out! :lol:
Re: Morrigans Zero
Postby Mark » Sun Nov 11, 2012 1:21 am
baby_astons wrote:haha, this one is even better...
http://www.youtube.com/watch?feature=en ... 7f1feSjDks
I'd have been really impressed if somebody got out after it landed :laughing-rolling:
Re: Morrigans Zero
Postby Paul » Sun Nov 11, 2012 2:53 pm
morrigan wrote:Now that would spin the neighbours out! :lol:
heck Morrigan, and I thought BA and I were bad !!!!!, I love it all !!!! :laughing-rolling:
Re: Morrigans Zero
Postby baby_astons » Sun Nov 11, 2012 3:51 pm
yes, notably superman :shifty:
Re: Morrigans Zero
Postby morrigan » Fri Nov 30, 2012 6:57 pm
Pack number 2 has arrived :-)
Which means more mods!
First up for experimenting is the rib bracing.
I grabbed my trusty Dremel and a diamond cutting wheel:http://www.dremel.com/en-us/Accessories/Pages/ProductDetail.aspx?pid=545
The cutting wheels can be obtained from evilbay.
I marked out the fine tubing with length and two marks for the end slots:
I then cut the tubing lengths, using a medium speed setting on the Dremel.
The ends of the tubing was then carefully notched:
Once the tubing was in place on the rib, I crimped the ends with pliers:
Nano dabs of Pauls favourite :superlglue: was applied to secure the bracing:
I did the same for the U shaped bracing as well, but being thinner metal, I dialled the speed down on the Dremel:
Now for the detachable spinner:
2 x 3mm neo magnets were :superlglue: to the spinner parts:
Even with a few mm of alloy in the way, two pairs of magnets still grip tight:
I'll put in a third pair for symmetry once some new stocks have arrived from evilbay.
Re: Morrigans Zero
Postby baby_astons » Fri Nov 30, 2012 7:14 pm
top notch bracing morrigan - mucho better than the suggested attachment from one side (and of course more prototypical as well!!)
Re: Morrigans Zero
Postby Mark » Fri Nov 30, 2012 11:39 pm
You must have the patience of a saint to slot all those tiny bits of tube, to say nothing of a steady had :o
Re: Morrigans Zero
Postby morrigan » Sun Dec 02, 2012 5:58 am
It Growed!
All the ribs supplied so far have been slotted in place:
I've used the supplied screws for now , I'll use bolts once everything is in its final place as they won't as easy to undo and replace as the screws.
Re: Morrigans Zero
Postby bufferz » Sun Dec 02, 2012 1:44 pm
gonna keep mine the aluminium colour, but I do like the aotake on the ribs....
In Progress: Endeavour, Zero, Yamato, Victory
Built: Orrery, Tellurian.
bufferz
Re: Morrigans Zero
Postby casper » Sun Dec 02, 2012 3:37 pm
coming along nicley Morrigan :D
Great idea for the bracing and magnets :clap:
Return to Zero
