Bufferz Zero
Bufferz Zero
Bufferz Zero
Postby bufferz » Wed Sep 19, 2012 5:30 pm
I fought and fought with myself over which to get, and the Zero won! Just subscribed today.....Dammit!! :D
In Progress: Endeavour, Zero, Yamato, Victory
Built: Orrery, Tellurian.
bufferz
Re: Bufferz Zero
Postby Julian » Wed Sep 19, 2012 6:37 pm
It sucks to be you, Bufferz :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Timmy Mallet
Re: Bufferz Zero
Postby Mark » Wed Sep 19, 2012 9:49 pm
Wot ? Me Jealous ?
:mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen: :mrgreen:
Re: Bufferz Zero
Postby steam60 » Thu Sep 20, 2012 8:49 am
Glad there is another Zero on the way,first tip get large magnifing glass to see those TINY screws :lol:
steam60
Re: Bufferz Zero
Postby Experten » Thu Sep 20, 2012 3:33 pm
Another tip about those TEEENY screws, magnetize the screwdriver! It makes a HUGE difference!
The crazy Yank
Experten
Re: Bufferz Zero
Postby bufferz » Thu Sep 20, 2012 9:16 pm
Cheers for the tips guys, im sure you will be getting mithered....never worked with metal before (Unless Meccano counts? :lol: ) Basically sat with the mrs and while i want to do all 3 of the Jap ones, she said she could see i really wanted to do the Zero, so do it, as although its pricey, its only the same overall cost as the SotS, and 6 months earlier too! Ive just got my CC payments set so the minimum payment is the £32 on direct debit, so in theory, i will never really see the debt as it will be straight out the bank! :dance:
bufferz
Re: Bufferz Zero
Postby Experten » Fri Sep 21, 2012 4:33 pm
Working with the aluminum and white metal isn't really any different than plastic, the material is just harder. You'll need a good set of needle files though, as well as extra sandpaper. Depending on which paint option you go with, you'll need gallons of metal primer. I use the Tamiya clear primer. It goes on well, but make sure you use it in a well ventilated area! You'll also want to use a good CA glue. The best stuff I've found for the metal is LocTite 454.
The kit is absolutely fantastic! You'll have such a great time with it, you'll forget about the cost, and start thinking about getting another one!
The crazy Yank
Experten
Re: Bufferz Zero
Postby morrigan » Fri Sep 21, 2012 8:37 pm
Don't tell the other half that Experten. I'm going to be in it for getting just one :lol:
Re: Bufferz Zero
Postby bufferz » Fri Sep 21, 2012 8:53 pm
Yeah, im looking at aerosol sprays (not confident enough o use an airgun! :whistle: ) not decided yet if im gonna go for a half and half or not, cos the skeleton detail is gorgeous....
bufferz
Re: Bufferz Zero
Postby steam60 » Sat Sep 22, 2012 10:17 am
I have been using car sprays from halfords for the primer (zinc grey) and from B and Q plasti kote spray cans (cost about £3) for the black,also lifecolor for the blue in a small airbrush,these spray well and the brush etc is easily cleaned in water,hope this helps regards
steam60
Re: Bufferz Zero
Postby bufferz » Sat Sep 22, 2012 1:47 pm
Yeah, never thought of halfrauds for the primer, ill buy some over the next month while im waiting for the plane.....28 days is a long time!! :angry-banghead:
bufferz
Re: Bufferz Zero
Postby Mark » Sat Sep 22, 2012 2:35 pm
I use Halfords White primer for everything. Brilliant stuff (and that's saying something as I really don't like high street chains !)
Re: Bufferz Zero
Postby bufferz » Wed Oct 03, 2012 4:38 pm
We are pleased to confirm that your next set of components will be despatched within 48 hours. You should receive these within 14 days.
Your next set-up instructions needed for your model's assembly are available to download. Please click on the following link and use your username and password previously supplied to access them.
bufferz
Re: Bufferz Zero
Postby bufferz » Thu Oct 11, 2012 6:40 pm
Look what's arrived..... :text-banplz:
24 to go....
bufferz
Re: Bufferz Zero
Postby bufferz » Sat Nov 17, 2012 10:03 am
Next pack arrived, much smaller though :cry: Starting the collection of "miscellaneous bits" ill need for it.... needle files - check, helping hands tool - check, magnifyer - check, just need the chemically stuff now!
Read the instructions for the 2 packs so far, i take it the ribs dont get sprayed with anything? Its just the blades and engine parts so far, or to the ribs need lacquering too? (Asking so I can work out how much primer/lacquer to order for it initially)
bufferz
Re: Bufferz Zero
Postby morrigan » Sat Nov 17, 2012 10:59 pm
I think the ribs are personal choice, they can be bare metal or Aotake.
From what I've read so far, as WWII progressed, less and less Aotake was applied to the interior of Japanese aircraft, particularly for aircraft destined to be 'Kamikazes'
Order lots of paint, especially if airbrushing, you'll be surprised at how much you go through! And there's nothing worse than running out of paint when the shops are closed.
Re: Bufferz Zero
Postby bufferz » Sun Nov 18, 2012 1:04 am
thats the problem, i have no idea how much aotake im gonna need, looking at the model its the engine, and landing gear mainly, ordered 1 can of the mr metal primer for the props so far, as i dunno how far that will spread either! Black is black, so i can source that, it was wether the wings needed priming if they arent getting painted, as im looking at the half skeleton approach...!
bufferz
Re: Bufferz Zero
Postby Experten » Sun Nov 18, 2012 10:10 pm
Hi,
I am re-painting my Zero for the umpteenth time. I was unhappy with my attempt to duplicate Aotake using Tamiya Transparent Green and Transparent blue. I have been using the Tamiya Primer. I switched to the LifeColor Aotake blue/green and ran into problems. The LifeColor orange peeled when applied over the Tamiya primer. I purchased some of the LifeColor primer, but have not had a chance to strip all my parts, and apply it.
Just a cautionary note!
The crazy Yank
Experten
Re: Bufferz Zero
Postby morrigan » Mon Nov 19, 2012 8:33 am
Thanks for the heads up Experten, I'll stick to my preferred Mr Hobby Mr Metal primer even though I have to get it surface shipped here.
I was almost going to switch to the Tamiya spray since I can get it locally, but if it doesn't play nice with acrylics and its twice the price of the Mr Metal I get online, I'll put up with the sllooow surface shipping.
bufferz wrote:thats the problem, i have no idea how much aotake im gonna need, looking at the model its the engine, and landing gear mainly, ordered 1 can of the mr metal primer for the props so far, as i dunno how far that will spread either! Black is black, so i can source that, it was wether the wings needed priming if they arent getting painted, as im looking at the half skeleton approach...!
Buy two jars to begin with, when you start on the second jar, buy another 1 or 2 jars depending on how fast you used up jar no 1. Also check how often the shop restock its paint ranges. Some will keep their paint stands full, or just keep one brand well stocked and others will sit empty for ages before being re-stocked. If its a slow restock, buy every last jar they have or go online.
Re: Bufferz Zero
Postby chill » Tue Nov 27, 2012 2:46 pm
Just been looking ahead on the Zero on the other website and theres some serious building and detail coming up.
I worry for you Zero Builders eye sight. :o
Return to Zero
