Giftek Robi the Robot
Any Radio Controlled model partwork series.
Postby giftek » Fri Oct 03, 2014 4:00 pm
Hi all
My first attempt to a build dairy, never done this so see how it goes this is going to be a long build especially as only get one issue a month
Parts looks clean started with the eye found a slight burr around the mold when attempting to stick the silver strip around best to clean surface of grease as strip not very sticky plus inner edge diameter slightly bigger then the outer which leave a slight ripple as on picture
that's it for first issue
Second Issue start the head assembly again nice molding the 3 part nicely align up with no problem, used tiny tip of grease on the screws this will help the ease of screwing the parts less stress and nice and smooth hint insert all 4 screws in before tightening down helps to square off
Eye Assembly now the black strip again degrease as very thin black strip i partially removed backing as on picture to align this will save you holding onto sticky end
Last attached the eye to assembly and the front mouth, nice fit all the holes align up again a touch of grease on screws partial screw them all in check alignment and bingo part 2 done. for part three only got two parts to fit suggestion protect the eye keep the sticker on it as very easy to scratch
Completed Victory, Titanic plus numerous airfix kits
Progress Bismarck, Bounty,
Collecting Sovereign of the Seas
Wish list everything else i can try to sneak into the house
giftek
Re: Giftek Robi the Robot
Postby steve131 » Wed Oct 08, 2014 2:35 pm
Nice work k awarded :clap:
Postby Chadders87 » Fri Oct 10, 2014 11:38 am
I'm jealous, I haven't been able to start mine yet. Soon hopefully :pray:
Have you considered applying a touch of Clear Coat to the eyes for extra shine and protection?
Also, are the eyes clear plastic painted with a black sheen, or is the plastic itself tinted?
Chadders87
Postby Mark » Fri Oct 10, 2014 2:51 pm
Are there any IR sensors behind the eyes ? If so, it might be worth checking that your clear coat doesn't block the IR signal.
Postby giftek » Sat Jan 24, 2015 4:32 pm
Fitting servo motor you do not need to remove the screws out of the body they will sit inside without falling out, fitting the cable make sure connection is firmly stuck down as can be intermittent on test,if not fully set home
giftek
Postby giftek » Sat Jan 24, 2015 4:58 pm
Attaching the body found easy to tape together before fitting the servo motor and neck part
Circuit board fitted plus fitted battery pack plugged in the lead but do not stick down the servo lead as you will have to unplug to setup other servo motors found out later after stuck down with tape
Do not stick down the servo lead as you will need to unplug later
giftek
Postby giftek » Sat Jan 24, 2015 5:05 pm
So far have completed the head assembly on which fitted onto the body , now getting worried as looking likely that the head will have to come off to fit parts inside the head as access would be difficult recommend not to fit the head onto server me thinks, too late for me so a very gentle removing the head as can damage if not done slowly as a very tight fit.
Also the arms this looks different to the finished Robi hmm thinking the arm is coming off later in the issue.
giftek
Postby giftek » Sat Jan 24, 2015 5:20 pm
Second servo instruction was to remove cover fit cable and re attached the same cover, pointless wait till next issue as you will have to remove the same cover and fit the arm part to it, on which then test and configure the servo, this is done at the main body there you will see that the head servo to disconnect and connect the arm servo to configure leave the head servo connection off as looks like a few servo will need to be configured from the main circuit board.
After servo all setup fitting the last part be careful wires can be trapped and pinched had to enlarge hole slightly so not to pinch the cable
thats up to issue 10 still getting one issue at a time taking forever
Pointless fitting the cover back on
Fitted arm this stage would be better now to test and configure servo
part came apart left if off you never know
This part need the hole to be slightly modified to stop the wire coming through being pinched
giftek
Postby Chadders87 » Thu Feb 05, 2015 5:01 pm
It may be slow giftek, but it's certainly taking shape!
What's the structural strength like?
Chadders87
Postby Chadders87 » Tue Jun 09, 2015 1:19 pm
Hey, how's the build coming along?
Chadders87
Postby giftek » Thu Jul 16, 2015 6:41 pm
Well been trying to find out what has happened as have had no delivery since May, it seemed to suddenly stopped have Email them a few times still no reply.
Hopefully will hear from them soon as been a long drawn out build
giftek
Postby giftek » Tue Jul 21, 2015 3:23 pm
well reply from Diagostini on delivery for Robi
Thank you for your email , kindly accept my sincere apologies for the delayed response on your query
Please be advised that we are aware that you have not received subsequent issues for your collection .We have not been given a date as to when we will get the stock however I can assure you that as soon as stock arrives, we will send them through to you.
We sincerely apologise for the delayed stock and any inconvenience caused in this regard .
Not only was i getting one issue per month now completely stopped only found out when chasing them as no delivery in June, this going to be a long wait especially at this rate, by the time this is completed it would be obsolete
giftek
Postby greyhawk » Tue Jul 21, 2015 4:27 pm
giftek wrote: by the time this is completed it would be obsolete
Well, that is a problem with all electronics, isn't it? :D
Building:
HMS Victory | HMS Victory X-Section | Schlachtschiff Bismarck
Citroen 2CV | Lamborghini Countach
Panzerkampfwagen VI Tiger | Grumman F14-D Super Tomcat
JNR Class D51 | Bayerische S 3/6
greyhawk
Postby giftek » Tue Jan 12, 2016 9:29 pm
Assemble of the left feet, well found the wire is shorter then showing in the magazine so was awkward in fitting to the motor so important to make sure it is well connected
Left feet
giftek
Postby giftek » Tue Jan 12, 2016 9:38 pm
Assemble so far on the robot the 2 arms and one feet so far at least now getting in a pack form, so progress should start
Fitting motor wire tight
Forgot to loop wire around the 2 holes
Assemble so for 2 arms and one feet
giftek
Return to R/C Models
