Mustang wrote:They look a lot better then the original ones, good find on them.
Once there painted and finished they be perfect, just need to look at the rear seats.
royjess wrote:Han Solo And Chewbacca
I've been looking into figures on sale that will fit the Falcon. The two closest that I been looking at are the Star Wars Battle Packs Unleashed and the Star Wars Command.FFTMF Thur 19 Feb 15 1 by Roy Lee, on Flickr
FFTMF Thur 19 Feb 15 2 by Roy Lee, on Flickr
The Unleashed are already coloured but are a tad too big and don't look right in the cockpit.
The command are closer to the correct size but will require painting. Either way they all will need modifying. These are about 8mm too tall, but in the sitting position, these are then only 4mm too tall.
The command pack I went for that contains both Han and Chewbacca is the Millennium Falcon set (Currently from Argos Half Price http://www.argos.co.uk/static/Search/se ... ommand.htm). This set also contains R2 D2, Darth Vader, Snow troopers and a Luke Skywalker (Hoth outfit). Other sets contain other characters but none seem to contain Princess Leia, Luke (Dantooine outfit), Ben Kenobie or C3P0.
Here are the command and unleashed figures side by side.FFTMF Thur 19 Feb 15 3 by Roy Lee, on Flickr
First thing that I had to do was to cut off the guns and stand and then dip the figures into boiling water to re-position the limbs. Immediately these were run under cold water to set hard. I also had to use a Dremel to sand the side of the upper legs and bottom to ensure these fitted into the seats. I also cut off the lower legs to fit better under the control panel.FFTMF Thur 19 Feb 15 4 by Roy Lee, on Flickr
Here are the figures test fitted.FFTMF Thur 19 Feb 15 5 by Roy Lee, on Flickr
I'll need to sand any rough edges and paint these. I might also need to apply a little bit of filler in places. I hope that the primer sticks to the plastic as the plastic content seem to have a high oil content, however, the paint should stick as the Luke and Vader figures have painted light sabers.
R2D2 wrote:I think Im going to stick with my 1/43rd figures for now unless Deagostini release a set at the end of the run! As Ive said in my earlier rant and rave in the "other improvments for the Falcon" thread Im happy with the model and as long as the figures are close to scale Im happy!
