Puma SA 330
Re: Puma SA 330
Re: Puma SA 330
Postby royjess » Thu Dec 10, 2015 9:05 pm
I'm pleased that your four legged friend found your rotary blade and didn't eat it :)
Re: Puma SA 330
Postby PhoenixPiper » Fri Dec 11, 2015 10:44 pm
This will definitely be a great build. So much that you are doing with this and keeping to the research. I hope it goes well :)
PhoenixPiper
Re: Puma SA 330
Postby Mustang » Sat Dec 12, 2015 11:54 pm
Managed to get sometime to start this.
First up I need to remove the top section.
From this.
To this.
Imager
This part will need to be split in half again.
Re: Puma SA 330
Postby Mustang » Sat Dec 12, 2015 11:56 pm
After removing the top section I've got the next problem which is the gap
To round this I'll insert a false roof and then fill the top gap.
Re: Puma SA 330
Postby Mustang » Sat Dec 12, 2015 11:59 pm
I've also be removing the right hand support
Once the bulkhead wall is in place you can see them from the doorway.
Re: Puma SA 330
Postby royjess » Sun Dec 13, 2015 10:34 am
This is going to be an interesting build and if your last years entries are anything to go by, this is going to be one to watch.
Re: Puma SA 330
Postby Mustang » Mon Dec 14, 2015 12:06 am
Soundproofing started.
Added to the false roof section.
This was achieved with some tin foil and scribing in the lines.
Re: Puma SA 330
Postby royjess » Mon Dec 14, 2015 3:05 pm
Your soundproofing has turned out well :clap:
Re: Puma SA 330
Postby Mark » Mon Dec 14, 2015 3:53 pm
I'll second that. Looks excellent :clap: :clap: :clap:
Re: Puma SA 330
Postby casper » Mon Dec 14, 2015 7:04 pm
Great idea using foil for the soundproofing mustang :clap:
what glue will you be using to fix it in place.
Re: Puma SA 330
Postby baby_astons » Mon Dec 14, 2015 8:38 pm
clever foil job mustang!! and a nice cutup just as well, you know I love chop jobs...
Re: Puma SA 330
Postby Mustang » Mon Dec 14, 2015 8:51 pm
Cheers guys.
Casper I just used double sided sellotape, then run some superglue around the edges.
Re: Puma SA 330
Postby Mustang » Mon Dec 14, 2015 8:56 pm
The rest of the soundproofing.
An extra piece of plasticard added to the end of the floor.
The corners will be glued down once this is fitted.
The Windows will also be moded just a simple sanding down if the edges.
You can see the difference in the first photo.
Re: Puma SA 330
Postby Paul » Mon Dec 14, 2015 9:09 pm
Hi Ian, the sound proofing looks excellent - where did you get the thought/idea from? :D :D
Re: Puma SA 330
Postby Mustang » Mon Dec 14, 2015 10:45 pm
Hi Paul.
I've used tin foil on other models a long time ago.
Easy to use and can be scribed easily.
Re: Puma SA 330
Postby Mustang » Fri Dec 18, 2015 8:13 pm
The next chop job as b_a puts it was the main rotor blades, I wanted them to be stowed so this meant I had to take them from the fixed position for flight to folded.
Sorry for the photos been doing this in the front room late at night.
This is how the kit has them
I had to get this part to swing back
Re: Puma SA 330
Postby Mustang » Fri Dec 18, 2015 8:20 pm
So the first thing I did was to remove the end of the blades.
This part was then glued to the rotor head.
Sorry forgot to take a photo at this point :angry-banghead:
After that I corrected the angle of the blades. ( during the day before going to work)
The following night I rebuilt the blades and head unit.
I first cut a groove into the end of the blades and inserted a piece of plasticard and then reshaped it to the correct shape and size, then I cut a groove into the rotor head to take the new piece of plasticard.
The out come was this.
I drilled .03mm holes for the pivot pins.
And yes they can be swang out back to there original position. :)
Re: Puma SA 330
Postby royjess » Fri Dec 18, 2015 11:21 pm
Looks like a tricky mod there which came out well :clap:
Re: Puma SA 330
Postby Mark » Sat Dec 19, 2015 4:29 am
Nice one Mustang. Have a K :D
Re: Puma SA 330
Postby casper » Sat Dec 19, 2015 8:53 am
Clever mod mustang :clap:
I would never have thought of altering the rotors, have a K
