Puma SA 330
Re: Puma SA 330
Re: Puma SA 330
Postby Mustang » Sat Dec 19, 2015 1:43 pm
Thank you a guys.
Roy it was a little pain, trying to cut a straight slot in the blade ends was the worst part as yo can see in one of the photos I had to re-pack the head unit and recut the slots as it went a bit wrong.
But I got there in the end :)
Hopefully today I can get the inside parts and some other bits primed, then get some painting done.
Re: Puma SA 330
Postby Mustang » Sun Dec 20, 2015 8:56 pm
Managed to get quite a bit done this weekend.
Rear Interior before.
After.
I've removed the first seats, as this version has a hook on the underside and as so the front seats are missing inorder to gain access to the cargo doors.
Re: Puma SA 330
Postby Mustang » Sun Dec 20, 2015 8:59 pm
The false roof installed.
Still a little work todo on the doorway as you can see in the photo.
Looking at the false roof from the outside.
I'm not worried about the mess left by the filler, there will be more used once the floor of the rotor unit is installed.
Re: Puma SA 330
Postby Mustang » Sun Dec 20, 2015 9:13 pm
I've also done the air intakes, this is the piece that comes in the kit.
This is what I've done to add the intake filters. First up added the internal roof section.
I found some piece in the spare box.
Re: Puma SA 330
Postby Gundog » Sun Dec 20, 2015 10:45 pm
I can't believe that a year ago you hadn't done any scratch building! Looking good.
In the stash: Way too much
Gundog
Re: Puma SA 330
Postby royjess » Mon Dec 21, 2015 12:53 am
The detailing that you are adding is looking really great! :clap:
Re: Puma SA 330
Postby Mustang » Mon Dec 21, 2015 5:18 pm
Thanks Roy, just a couple more mods todo, once the main kit is fitted together.
Re: Puma SA 330
Postby Mustang » Thu Dec 24, 2015 6:04 pm
Gundog wrote:I can't believe that a year ago you hadn't done any scratch building! Looking good.
Scary Gundog, with in a year how much info one can gain. ;)
Re: Puma SA 330
Postby Paul » Thu Dec 31, 2015 3:36 pm
Absolutely excellent Ian !!!! :D :D
Unfortunately I must spread my "K"'s though :oops:
Re: Puma SA 330
Postby Mustang » Sat Jan 02, 2016 9:00 pm
Little bit done, not had much time to do any over the last couple of weeks.
Added central fire wall.
Fitted front air intakes, that was a pain to get right.
Extra detail added.
Re: Puma SA 330
Postby royjess » Sat Jan 02, 2016 10:52 pm
This is coming along nicely with all the additional detailing. Well done :clap:
Re: Puma SA 330
Postby Mark » Sun Jan 03, 2016 4:20 am
Very impressive detailing Mustang :clap: :clap: :clap:
Re: Puma SA 330
Postby Mustang » Sun Jan 03, 2016 7:21 pm
Cheers guys.
Rear exhaust, and oil cooler.
Re: Puma SA 330
Postby Mustang » Sun Jan 03, 2016 7:24 pm
Slight problem lost one of these. :angry-banghead:
So made two new ones from brass rod
Added so much to the top area, needed to make sure it was still level once the wheels are added on the rear.
Re: Puma SA 330
Postby Gundog » Sun Jan 03, 2016 8:18 pm
Coming along a treat :D
Gundog
Re: Puma SA 330
Postby royjess » Sun Jan 03, 2016 9:24 pm
Gundog wrote:Coming along a treat :D
I second that :clap:
Re: Puma SA 330
Postby Mustang » Fri Jan 08, 2016 4:35 pm
Not going to get this finished in time, so I've asked Casper to move it to the Aircraft section.
So this build is removed from the comp.
Re: Puma SA 330
Postby baby_astons » Fri Jan 08, 2016 7:09 pm
really some incerdible detailing mustang, very impressed!
Re: Puma SA 330
Postby casper » Fri Jan 08, 2016 8:03 pm
excellent build mustang :clap: :) love all the scratch building
Re: Puma SA 330
Postby Mark » Sat Jan 09, 2016 6:32 am
I agree, its going to be a brilliant model. Shame it won't be in the Xmas comp, but it's not worth rushing it.
