Puma SA 330
Re: Puma SA 330
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:31 pm
baby_astons wrote:really some incerdible detailing mustang, very impressed!
Thanks b_a that means a lot as your work I've seen is fantastic.
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:32 pm
casper wrote:excellent build mustang :clap: :) love all the scratch building
Cheers Casper.
Still got some more to do, front ariel system, rear box under window area, hook for underneath. :think: that's it
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:37 pm
Mark wrote:I agree, its going to be a brilliant model. Shame it won't be in the Xmas comp, but it's not worth rushing it.
Thanks Mark, I hope it turns out the way I see it in my head :angry-steamingears:
I asked Casper has I don't think I would have enough time to finish it, got this week off but house work needs doing and as I didn't have much Christmas time I'm trying to catch up with mates. There's only a come weekends left so I thought it would be a push to finish it in time.
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:42 pm
So I've managed to do a bit more today, but first I forgot to show that I had added the drive shafts that run inside the exhaust system.
I've had a bit of a day with this broke one of the undercharge systems :angry-banghead: so replaced with some brass rods.
Also managed to break off two main blades while I was trying to work out the rear holding arms, so out with the :superlglue: and refit them :angry-banghead:
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:47 pm
So this is how she looks at the moment.
The side doors and front canopy where just laid in place to check the weight, as this is now tail heavy with all the extra bits.
The supports are as close as I'm going to get them, there not correct but this was my third attempt at trying to make them.
Drilled out some of the holes on the side and will be adding some mesh to the cut out on the tail section just below the blades.
Re: Puma SA 330
Postby Mustang » Tue Jan 12, 2016 7:55 pm
Oh yes the cut line in the front engine case is because once these are lowered into the open position they will have a slight angle, the little bit at the bottom sits against the helicopters body while the rest of the cover comes out at a 90deg angle.
So I've cut a groove into the front in order to allow me to bend them. Hope that make sense :think:
Re: Puma SA 330
Postby Mark » Wed Jan 13, 2016 12:26 am
Love the detailing Mustang. Shows what can be done without aftermarket parts if you try !
Re: Puma SA 330
Postby Mustang » Wed Jan 13, 2016 2:55 pm
Cheers Mark, I'm not 100% sure about the white piece on the support beams.
Might have to have a re :think: about them.
Re: Puma SA 330
Postby casper » Wed Jan 13, 2016 11:06 pm
excellent work mustang :clap: :clap:
Re: Puma SA 330
Postby Mustang » Thu Jan 14, 2016 10:07 pm
Cheers Casper.
I've had some spare time so here's some more.
First up the runners for side doors look to heavy.
So I've redone them.
All done with some brass L and U shaped pieces
Re: Puma SA 330
Postby Mustang » Thu Jan 14, 2016 10:18 pm
Here's some more photos, all I can say is if it's not grey it's been added. ;)
Added some brass to the rear.
The brass pin will be for the ariel system, the one lower down is a pipe. The white piece no idea.
Same as above.
Added a little piece to the top of the fin.
Just to show its still a 1/72 model. ;)
Think I need to go to the asylum now ;)
Re: Puma SA 330
Postby steve131 » Thu Jan 14, 2016 10:26 pm
:clap: Nice runners
Re: Puma SA 330
Postby Mustang » Fri Jan 15, 2016 9:09 pm
Thanks Steve.
Done all the upgrades I can think of.
Added a unit to the rear.
A small shark fin, this was a fin of a missile in my spare's box.
Front ariel system. This was made from a piece of plastic sprue.
I've removed the two upright ariel until I've painted the model.
Re: Puma SA 330
Postby Mustang » Fri Jan 15, 2016 9:18 pm
So with all that done, onto the last bits like adding the windows and doors.
The first side fitted fine :) but the second one well :angry-banghead:
So while trying to sort this out I had a bit of a :o :o :angry-banghead: :angry-banghead: while trying to sort the door and roof section I managed to do this :( :(
Ripped all the roof section off :oops: :oops:
The door was then sorted, the filler looks bad but it's been sanded and redone so all is ok.
Then I had to refit all the parts I ripped off.
The next update will be once it's been painted.
Re: Puma SA 330
Postby Mustang » Fri Jan 15, 2016 9:43 pm
Might help you all if I link in what I'm hoping this will look like when finished.
http://www.primeportal.net/hangar/paul_ ... /index.php
Re: Puma SA 330
Postby royjess » Sun Jan 17, 2016 7:10 pm
My daughter has just pointed out to me that you have pulled this build from the comp and move it. It is a shame, but I do fully agree that you should not rush it if you feel that you need more time to build it. What I can see, so far you have done an excellent job and I must remember to follow this build.
If by any means you do happen to finish the build by the end of the month, I sure that it will be OK for you to still enter it in the comp. You've certainly raised the bar this year with this build.
Roy :)
Re: Puma SA 330
Postby Mustang » Sun Jan 17, 2016 7:58 pm
Hi Roy thanks for the nice comments ;)
I asked for it to removed as I wasn't sure about the time it would take to complete, but I've managed to get most of this completed in the last couple of days. It's all primer'd and awaiting a top coat of orange the main rotor system is done and painted.
If I manage to get this completed before the time runs out then yes I will re-enter it, I only ask for it to moved as I now Mark locks the builds off. And if I hadn't finished in time I would be able to update the diary, but I'm sure Mark would have sorted something out ;)
So thank you for allowing me to re-enter this if I can complete it in time ;)
Re: Puma SA 330
Postby Mustang » Sun Jan 17, 2016 9:03 pm
So I've primer'd the model and started painting, simple colour scheme white underneath and orange top.
Another small mod I've done was to add some detail to the inside of the engine covers. I've only given it a light coat to see what the colour would look like, I'm happy with the colour so another coat tomorrow.
Re: Puma SA 330
Postby Mustang » Sun Jan 17, 2016 9:08 pm
Main rotor unit completed, all brush painted.
Yellow will need some touching up, I'll wait it its all fitted together.
Fuse wire used for the wiring system.
Re: Puma SA 330
Postby royjess » Sun Jan 17, 2016 10:31 pm
This build is awesome and I'm please to hear that there might be a possibility that you might just finish it in time to enter it into the comp.
