My Thunderbird build
Re: My Thunderbird build
Postby R2D2 » Thu Aug 02, 2018 9:26 pm
The elevator cars 1 and two. There are actually four of these so there are still two to build yet.
Postby R2D2 » Thu Aug 02, 2018 9:29 pm
One of the recovery vehicles and Thunderbird 4.
Recovery vehicle 2 and fab 1.
Postby R2D2 » Thu Aug 02, 2018 9:31 pm
Front of Thunderbird 2. All functions are still working although I have yet to fit the 8 channel IR unit to control them all.
Postby R2D2 » Thu Aug 02, 2018 9:32 pm
Pod laying in Thunderbird unit. This has yet to be finished.
Postby R2D2 » Thu Aug 02, 2018 9:33 pm
Low shot of some of the vehicles to show size of Thunderbird 2.
Postby R2D2 » Thu Aug 02, 2018 9:34 pm
Had to have another pic of Thunderbird 4.
Postby R2D2 » Mon Aug 13, 2018 12:44 pm
Made a start on the Thunderbird Launch Bay! Made from light 5mm foamboard! This is the main box section which will be the main wall sections that all the bits will be glued to inside!
Postby R2D2 » Mon Aug 13, 2018 12:50 pm
Its absolutely huge even in 1/144 scale! Measures 85cm long X 62cm wide X 40cm high! The left hand wall will be open and the front will not be fixed so it can be removed to see the inside!
Shot taken from the opening front!
Postby R2D2 » Mon Aug 13, 2018 12:51 pm
Parts of so far finished Thunderbird 2 and pod sitting inside to show size!
Postby R2D2 » Mon Aug 13, 2018 12:53 pm
Side view! Looking very bare but I'm hoping it will look like the picture below when I've finished!
Postby R2D2 » Mon Aug 13, 2018 12:55 pm
This is what I hope it will look like when completed. There's a lot of work involved!
Thunderbirds Launches and Landings HD_Moment2 small.jpg (107.53 KiB) Viewed 2090 times
Postby steve131 » Mon Aug 13, 2018 3:36 pm
Coming along nicely ,will be great when finished.
Postby wingnut2 » Mon Aug 13, 2018 4:14 pm
R2D2 wrote:Made a start on the Thunderbird Launch Bay! Made from light 5mm foamboard! This is the main box section which will be the main wall sections that all the bits will be glued to inside!
Coming along nicely John :clap: what glue do you use to stick that "board" together ?
Postby R2D2 » Mon Aug 13, 2018 4:57 pm
Didn't use glue but used a strong glue based tape! It holds really well! The parts inside though will have to be glued and I recon the best way will be to use super glue on the smaller parts and a hot glue gun for the bigger parts! As for the girders I know someone who has a 3D printer and is making me some! I will need quite a few but he's only charging me for the cost of the plastic extrusions! Here is a picture of the first test run of them so far next to one that is 350th scale!.
s-l1600aa smaller.jpg (150.17 KiB) Viewed 2084 times
Postby wingnut2 » Mon Aug 13, 2018 5:25 pm
:o both sizes look perfect !
Postby R2D2 » Mon Aug 13, 2018 5:37 pm
The only problem is I need 52 of them so it will take a while to print them out!
Postby wingnut2 » Mon Aug 13, 2018 5:41 pm
Hi John, 52 :o :o sooner you than me :angry-banghead: :angry-banghead: :laughing-rolling:
Postby R2D2 » Mon Aug 13, 2018 5:51 pm
Could be worse! I've got to work out the dimensions of the insides and how and where to fit certain parts! I've managed to down load quite a few pics of the inside of the loading bay and also looked at videos! There's a lot of work to do! Its also going to be lit with LEDs and have an operating loading shoot for the pilot!
Return to Sci-Fi
