My Thunderbird build
Re: My Thunderbird build
Postby royjess » Sun Mar 25, 2018 4:51 pm
To load a video, you need to either upload it to youtube or some other similar site like Facebook and then post the URL link here.
I do have instructions on how to embed the videos on here, unfortunately the flash needed is disabled for the non mods, so people will have to click on the URL link to view
Postby R2D2 » Sun Mar 25, 2018 5:05 pm
Thanks for your info Roy. Will have to take a video and try it!
Postby Paint_With_Penny » Fri Mar 30, 2018 5:39 am
To embed a you tube video you need a flash BB code. However, it doest work and needs to be manaually adjusted. Drop the admin a note and speak to him, Ive found him to be a very helpful guy.
Current Builds
    London Classic Routemaster
    Harley Davidson Fatboy
    Millenium Falcon
Completed Builds
    Woo, Steady On There cowboy
Paint_With_Penny
Postby R2D2 » Fri Mar 30, 2018 7:38 am
Thanks or the info Penny, but for now some more stills. Upper hatch and missile launcher now work from motors.
Postby R2D2 » Fri Mar 30, 2018 7:40 am
These are the motors driving the operating parts! Internal lighting will be controlled by the IR control as well.
Postby R2D2 » Fri Mar 30, 2018 7:41 am
Another view of upper drive motors.
Postby R2D2 » Fri Mar 30, 2018 7:43 am
Both upper and lower sections temp fitted together. 4 micro geared motors taking quite a bit of room but still space to fit IR controller and other parts yet to come!
Postby R2D2 » Sun May 06, 2018 11:11 pm
Received my pack 2 at last! this comprises of 8 issues as I will now get pack 3 in two months time because I'm on 24 month subscription. It means Ive got a long wait until the next pack but this is the way they work the system. The first parts are the window covers. I'm modifying these to have clear Perspex, cameras, and lighting!
Postby R2D2 » Sun May 06, 2018 11:13 pm
Next part is main body section. This is screwed to the lower front. Makes the model look much larger than I thought!
Postby R2D2 » Sun May 06, 2018 11:14 pm
Underside of main body!
Postby R2D2 » Sun May 06, 2018 11:15 pm
Next part is rear hull section for upper front cabin!
Postby R2D2 » Sun May 06, 2018 11:16 pm
Rear section screwed in place!
Postby R2D2 » Sun May 06, 2018 11:17 pm
Front section just temp fitted in place! Starting to look the part now!
Postby R2D2 » Sun May 06, 2018 11:18 pm
Next part is battery box and switch fitted to rear of main body!
Postby R2D2 » Sun May 06, 2018 11:20 pm
Cameras fitted to front windows. Not very visible in this pic but take my word you can see them!
Postby R2D2 » Sun May 06, 2018 11:22 pm
Window lit up! You can just see outline of cameras! They do look better than in the photo "Honest"!
Postby R2D2 » Sun May 06, 2018 11:24 pm
1st rescue vehicle plus rear wall section! This has yet to be built as is rescue vehicle 2!
Postby R2D2 » Sun May 06, 2018 11:26 pm
More rescue vehicle 1plus front intakes!
Postby R2D2 » Sun May 06, 2018 11:27 pm
Parts for rescue vehicle 2!
Postby R2D2 » Sun May 06, 2018 11:28 pm
More of rescue vehicle 2 plus lower VTOL boosters!
Return to Sci-Fi
