Red 5 Standing By
Red 5 Standing By
Red 5 Standing By
Postby Narayan » Tue May 21, 2019 2:27 pm
Greetings!
I got my first 2 parts for the X-Wing Fighter subscription today so thought I would start a build thread.
First up, some of the equipment I will be using.
With the first 2 issues I am provided with a series guide:
and some blue prints:
I haven't had a chance to make a start yet but wanted to post an introduction to the build. I hope to get started soon.
Narayan
Re: Red 5 Standing By
Postby number1 » Tue May 21, 2019 3:54 pm
Hi Narayan, looking forward to your build, popcorn on order, :handgestures-thumbupright:
Postby casper » Sun May 26, 2019 9:41 am
Hi Narayan :)
really good to have an X-Wing build thread, will be watching your progress :)
Postby Narayan » Tue May 28, 2019 1:48 pm
Greetings!
Thanks for your good wishes Number1 and Casper.
Starting off with Issue 1 then. We have the Cockpit canopy, part of a laser cannon and some of R2-D2.
Firstly the two parts of the canopy click together.
It feels a little flimsy at the moment but will be more solid when the glazing has been applied and it is fitted to the hull.
Next come the barrel sections of a laser cannon. A small amount of glue was applied to hold the pieces together firmly.
Finally for this stage R2-D2s dome had 3 projectors applied. One of these required a little glue.
That finishes stage 1.
Narayan
Postby Narayan » Tue May 28, 2019 1:52 pm
Stage 2 includes the cockpit base, more parts of a laser cannon and additional R2-D2 pieces.
Starting with R2.
These parts are pushed together.
The laser generator includes an LED.
Again all parts are pushed together.
The cockpit base is set aside for now and that is stage 2 complete. The laser cannon and R2-D2 should be completed over the course of the next 2 issues.
Narayan
Postby casper » Mon Jun 03, 2019 7:12 am
Great start Graham :) Looks like the Drs Screwdriver
Postby Narayan » Wed Oct 23, 2019 8:50 pm
It's been a while since I was able to get to this build. Picking up where I left off with stage 3.
Beginning with R2-D2's right leg.
For some reason I'd didn't take a picture of this when it is closed up. But you'll see more of R2 soon anyway.
Next was the cockpit assembly. The base of which was received in an earlier issue.
Finally for this stage the laser canon started to go together.
I'll try and do better with progress shots in future.
Narayan
Postby Narayan » Wed Oct 23, 2019 9:49 pm
On to Stage 4.
First up the cockpit base. Just side panels to add here.
Next was R2-D2. Putting the body together was a little awkward getting everything to stay in place so I couldn't take any pictures until it was together.
Next I added some plastic see through parts in the head and tested the lighting. This didn't work so I had to fiddle around with a couple of bits. I eventually worked out the connectors were the wrong way round. If I had just turned the page in the magazine I would have seen straight away this is a common error!
To finish the laser cannon I have to take apart the pieces I did earlier so I can add fibre optic. It did offer a tip to paint the end of the casing. This is because there is a light source in here and you might notice a glow when the cannon 'fires'. By painting this part black the glow should be concealed.
So I will leave it there tonight while the paint dries.
Narayan
Postby Narayan » Thu Oct 24, 2019 9:39 am
The laser cannon has been put back together with fibre optic inside and the suppressor added at the end. I tested the light at the end of the cannon but couldn't get a decent picture.
That completes stage 4.
Narayan
Postby Narayan » Thu Oct 24, 2019 8:11 pm
Stage 5: R2-D2 and Cockpit Instruments
First up is R2's leg. A couple of fiddly bits here which are easiest to add using tweezers.
Clear plastic parts are put inside the cockpit instruments. These will light up at a later stage when LEDs are put in the cockpit.
Narayan
Postby Narayan » Thu Oct 24, 2019 8:23 pm
Stage 6: Cockpit Shell
Quite straightforward. Attach the 2 instrument panels to the cockpit shell using screws provided.
Narayan
Postby Narayan » Thu Oct 24, 2019 9:29 pm
Stage 7: Upper Starboard Wing
First the trailing edge detail clips into the wing.
Power couplings are added to the underside, again they clip in.
This is what it will look like when a laser cannon is added later on.
Narayan
Postby Narayan » Thu Oct 24, 2019 10:06 pm
Stage 8: Upper Starboard Wing cont...
The metal frame is screwed into place.
The trailing edge wiring and conduit are then clipped into place.
Followed by the leading edge wiring and conduit.
Finally the wing root brace is also clipped into place.
The wing now looks like this:
Narayan
Postby steve131 » Tue Nov 05, 2019 8:34 pm
Great work coming along nicely.
Postby Narayan » Sun Nov 17, 2019 11:34 pm
Thanks Steve.
Moving on to Stage 9: Upper Starboard Engine Mount.
Detail is added to the leading edge support which is then attached to the engine mount.
Next the engine mount will be attached to the upper wing from the last stage.
This is further attached by a support bracket. The last of 5 holes in this bracket should not be screwed in at this stage.
Narayan
Postby Narayan » Sun Nov 17, 2019 11:36 pm
Stage 10: Assembling the Engine
Quite straightforward. These pieces clip in. They are pretty tight so you need to ensure everything is the right way round as it would be difficult to take them apart if not.
Narayan
Postby casper » Mon Nov 18, 2019 5:19 pm
wow stage 10 already :) great pics Graham thanks for showing us your progress
Postby Narayan » Tue Nov 19, 2019 12:35 pm
Thanks Casper. I have 4 more stages to catch up on.
Stage 11: Upper Starboard Engine.
First of all the fission chamber half and fission chamber mounting are put together and added to the engine casing.
There are now 9 plant on details that are added to the outside of the engine casing.
All straightforward. No screws required for this stage, everything fits nicely in by pins.
Narayan
Postby chill » Tue Nov 19, 2019 1:41 pm
Good work so far.
Good to see the parts are push-fit. Is the friction enough to hold the parts in? Or are you applying a dab of glue at the back for a sure fit?
Postby Narayan » Tue Nov 19, 2019 7:52 pm
chill wrote:Good work so far.
Thanks Chill. I used a little bit of glue on the barrel of the laser cannon but that's all. Everything else that doesn't require screws has gone together very nicely.
Narayan
Return to Sci-Fi
