Iron Man Test
Iron Man Test
Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:03 pm
I have issues 1 & 2
Having read the build instructions and checked the parts there are a few discrepancies but nothing that cant be overcome.
issue 1 - the helmet - differences, in the mag the led support and battery box are shown as being white whereas they are actually red
issue 2 - the left foot - differences again the led support and battery box are shown as white in the mag but are red. also the two washers are shown as white but are also red plus some of the screw designations are wrong as you will see.
pics of the parts
IM 1.JPG (20.19 KiB) Viewed 3508 times
IM 2.JPG (19.77 KiB) Viewed 3508 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:05 pm
first of all the support rod is attached
IM 1A.JPG (21.42 KiB) Viewed 3507 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:06 pm
next up the battery box is fixed in place
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:07 pm
the led diffuser is then clipped into place
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:09 pm
next up the leds are pushed into the led support and then screwed into place
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:12 pm
The helmet support was the attached to the base plate
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:15 pm
according to the instructions the base plate was to be screwed to the bottom half of the helmet before the switch is screwed into place BUT it was easier to attach the switch beforehand and then attach it to the lower half
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:18 pm
The switch activator was then assembled
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:20 pm
the activator was slotted into the lower half then the two halves joined together
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:22 pm
The batteries were then inserted and the cover put on
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:23 pm
The visor and clip were added to the faceplate
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:24 pm
finally the faceplate was put in place (its held on with a magnet)
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sat Sep 28, 2019 7:26 pm
overall a relatively easy build but a bit fiddly in places
a pic of the helmet lit up
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:18 am
Issue 2 - The left boot
first the ankle joint is attached
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:21 am
next the switch/battery box is fixed in place. The instructions say to use a DM screw to hold the switch in but it is actually a CM screw that is used, an AM screw is used to hold the battery box in
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:24 am
A diffuser and led support are added to the boot heel
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:26 am
the led is inserted into the support and then the heel is bolted to the top of the boot. the instructions say to use BM screws but it is DM screws that are used.
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:29 am
The toe cap is then fitted. instructions say to use CM screws but EM screws are the correct ones.
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:30 am
The boot sole is then added to the toe cap
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:31 am
The battery cover is then attached after inserting the batteries
Nick
corelki2005
Return to Sci-Fi
