Iron Man Test
Re: Iron Man Test
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:34 am
The led is tested
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:36 am
Finally what they call the vamp is affixed (magnetic cover)
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Sun Sep 29, 2019 9:43 am
The only downside I can see is the scale of the model
I think this model is around 1/3 scale as it is approx. 600mm tall. It should of been 1/2 scale 900mm tall, then it would be similar to the Terminator :D
At present I haven't decided whether to actual continue with this if it goes live.
Nick
corelki2005
Re: Iron Man Test
Postby Mark » Mon Sep 30, 2019 5:50 am
That's looking really good. Looks nice quality and well finished.
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:00 pm
issue 3 - the right gauntlet
the parts
issue 3.JPG (22.23 KiB) Viewed 3328 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:01 pm
first off the fingers and thumb are assembled
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:02 pm
the diffuser was then added to the palm
Palm 1.JPG (14.72 KiB) Viewed 3328 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:03 pm
the battery box was fitted to the outside of the palm
Palm 2.JPG (16.16 KiB) Viewed 3328 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:06 pm
the fingers were then sandwiched between the two halves of the palm, the battery cover added and finally the hand guard attached
Gauntlet 1.JPG (19.8 KiB) Viewed 3328 times
Gauntlet 2.JPG (16.14 KiB) Viewed 3328 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:07 pm
the gauntlet with the palm lit up
Gauntlet 3.JPG (12.9 KiB) Viewed 3327 times
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 10, 2019 5:09 pm
if this is a 4 issue test run then hopefully next week I should have the arc reactor
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:14 pm
Issue 4 - the arc reactor - the last of the test issues
not a lot to do in this issue compared to the previous three.
parts
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:15 pm
The inner ring and the diffuser were inserted into the main ring and then secured
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:16 pm
the led was inserted into the support disc
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:18 pm
a clear cover was then put over the led and the whole lot screwed together
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:19 pm
the supplied batteries were then inserted, the cover attached and the switched on to test
Nick
corelki2005
Re: Iron Man Test
Postby corelki2005 » Thu Oct 17, 2019 3:23 pm
there you have the four issues. If this goes live and after my routemaster is finished then I may subscribe to it
Nick
corelki2005
Re: Iron Man Test
Postby steve131 » Sat Oct 19, 2019 10:43 am
Did part one myself ,quality excellent and very much enjoyed doing it . Would be a fun build, into a cracking model.
Re: Iron Man Test
Postby Narayan » Wed Oct 23, 2019 7:44 pm
Thanks for posting, this looks interesting. Hopefully it will go live.
Narayan
Return to Sci-Fi
