Hachette Fiat 500 Abarth
Re: Hachette Fiat 500 Abarth
Postby Andrewyzfr6 » Sat Feb 04, 2012 8:35 pm
parts 23-26
parts 27-30
wiring going the rolling chassis
Postby Andrewyzfr6 » Sat Feb 04, 2012 8:37 pm
underside nearlycomplete until the final part of the build
rolling chassis
Postby Andrewyzfr6 » Sat Feb 04, 2012 8:38 pm
parts 31-34
parts 35-38
Postby Andrewyzfr6 » Sat Feb 04, 2012 8:59 pm
floor on
seats in
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:01 pm
ariel view
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:02 pm
41-43
44-46, and the door outer from the begining
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:04 pm
door internals
window regulator being built, the windows are wound up and down by the door speaker!
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:06 pm
dashboard and internal parts
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:12 pm
all lit up! There is no photos showing me putting the dash ii and getting the lights working as I lost the plot a few times. The dash wiring got broken and a micro switch came loose after being built. A local electrical engineering firm cured it for a free MOT!!!
Postby Andrewyzfr6 » Sat Feb 04, 2012 9:16 pm
A few parts required a bit of fettling to be fitted. The rear seats were supposed to snap together, but required gluing, and as previously mentioned the dash micro switches were loose (i broke the wire!)
Postby Mark » Sun Feb 05, 2012 3:22 pm
That's turning into a sweet (not so) little model.
Postby Paul » Mon Feb 06, 2012 2:42 pm
Wow Andrew,
It looks an excellent model :D :D :D .......
I wish that they'd release it in the UK !
Postby Andrewyzfr6 » Sat Feb 11, 2012 8:59 pm
Thanks Paul, it is generally a good model with slight build quality issues. Nothing serious tho.
If they did release it in the uk would they put the steering on the correct side?( I'm not changing this over,lol)
It'll look good next to the db5 and I have a ducati 998 in 1/8th too, so I'm planning to get a few more 1/8 models, but other than plastic kits there isn't many on the Market.
I have a few more photos to resize yet, but I haven't had the chance, been busy.
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:04 pm
The last photos, sorry i never photograhed every stage!
side interior panels on.
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:06 pm
roof interior panel on
tailgate on
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:07 pm
sill on next:
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:10 pm
door on. It was a pig to get the screws on tight enough to support the door. Proper snap on screwdriver helped so i could get the torq!
roof panel on with ariel fitted.
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:12 pm
Skyremote for size! nearly finished!
Postby Andrewyzfr6 » Thu Feb 23, 2012 10:13 pm
finihed and lights on!
from the rear
Return to Other cars
