baby alfa romeo duetto spider 1:8
Re: baby alfa romeo duetto spider 1:8
Postby baby_astons » Mon Sep 23, 2013 10:42 pm
now gents, a very large update with the parts up to #28 (everything I fetched while on holidays in tuscany...)
first up are three that were missing from the first set of pictures:
#8 front lower body panel (massive painted metal)
#9 driver side lower fender panel including indicator + wiring
#10 passenger side lower fender panel including indicator + wiring
#16 starter, dynamo + hardware
#17 water hoses + first part of the water cooler, oil filter
#18 water cooler, fan + rest of the cooling hardware
#19 weber carburator assembly + intake manifolds
#20 air filter and air intake + battery + hardware
more lovely parts in the next post...
Postby baby_astons » Mon Sep 23, 2013 10:53 pm
#21 washing baggy, electrical hardware for the engine compartment
#22 complete engine compartment tray, including assembled electrics, all plastic
#23 front exhaust assembly
#24 rear exhaust assembly
#25 tada! may we present the chassis - it's all plastic and it's a mighty part and very complicated looking
#26 fuel tank hardware + hoses
#27 fuel tank + front crossmember assembly
that's it for now - almost all body parts will attach to the plastic chassis but we'll get all kinds of metal brackets so the big plastic lump won't bend or break -
so next up are two relatively dull issues containing a few of these brackets, thereafter two issues with front suspension pieces,
quite pleased how the parts look like and also with the desctructions: we have over 120 pages full of great pictures right now, and the binder is lovely as well, picture next time...
Postby Mark » Tue Sep 24, 2013 2:55 am
It looks like a superb model. I'd be sorely tempted if it was a British classic sports car.
Postby casper » Tue Sep 24, 2013 7:44 am
looks very nice BA :) thanks for the pics
Postby baby_astons » Sat Dec 07, 2013 6:02 pm
just about time to update this a bit with the next issues:
#28 chassis metal bracing/hardware LHD
#29 chassis metal bracing/hardware RHD
as some will recall, the chassis is a big plastic lump - in order to keep it straight and safe these parts are assembled to add strenght...
#30 two front springs + a pair of pliers, even these are supplied with the kit
#31 RHD front suspension parts
#32 LHD front suspension parts
#33 front suspension bridge, a heavy metal part ready to take the load of the car...
#34 rear axle outer parts
#35 rear RHD trailing arm and spring
#36 rear LHD trailing arm and spring
#37 differential internal assembly
#38 rear axle parts + main drive shaft
#39 steering linkage and front axle finishing parts
that's it for today, next 2 issues already stored for me, I'm getting the parcels now every dozen or so parts, depending on the weight...
so by time the next arrives here we'll be half way through the parts count, should decide what paint the car will get, it won't stay red for sure...
Postby Andrewyzfr6 » Tue Dec 10, 2013 12:05 pm
i must consider buying this too! i think i will wait until its fully published to buy the whole lot at once like i did with the 500 abarth.
Postby baby_astons » Mon Jan 06, 2014 11:45 pm
...haven't seen this kind of thing yet but hachette italy made us a rather unpleasant surprise with the first new issue in 2014:
the copy price has gone up from 9,99 to 10,99 - even if they had all issues from #4 to #100 marked as 9,99 in the first place -
I won't be complaining officially as it's coming from italy via a good fellow but I don't quite know if this would be legally allowed if one appealed...
which btw means they've elevated the total by 55€ (as charging one € more for each of the last 55 issues)... :snooty:
Postby baby_astons » Mon Mar 17, 2014 6:46 pm
time for a small update on the alfa (should it be baby blue, or at least baby blue metallic...)
#47 internal door gap trailing and closing gap panels LHD + sill chromework
#48 complete window assembly LHD door
#49 internal window winder assembly including inner panel LHD
#50 door skin including handle + hardware LHD
#51 inner door panel including hardware LHD door
#52 replicating #46 i.e. door sill, this time RHD
#53 is the same as #47 just RHD,
so consider the pictures uploaded up to part #57, the RHD inner panel inlcuding hardware as I won't do it here, hachette is giving us the details of the next issues around 3 issues in advance so at the moment I don't know what is awaiting us, just to say, we have already received more than 50% of the car (precisely 55% as it's 55 issues we have so far...
we've got the engine + suspension completed, also most parts of the front bodywork including doors (with the bonnet missing yet), so the rest of the parts will deal with the interiour, the boot and the rest of the body panels... particluraly interested to see the fold-away fabric roof parts :D
btw. the bright guys around here will have noticed that a grey package means, the parts are painted (heavy) metal pieces...
Postby Roymattblack » Wed Mar 19, 2014 5:25 pm
If this had hit the UK shores I would have been in!!!
Gorgeous car - lovely build.
Now I'm on a Google-mission to find a kit.....
Roy.
Roymattblack
Postby baby_astons » Wed Mar 19, 2014 10:08 pm
hello roy, might be a bad karma - as it seems I got the only 4 parts (the first 4 numbers) off italian ebay that were ever on sale there -
if you have someone who could get you the parts from there that would be the best idea - I think I am "using" my contact to the extent that he wouldn't be willing to get another set of parts -
you might have someone frome bay who'd be willing...
Postby baby_astons » Wed Apr 09, 2014 10:46 pm
now i've found what i was looking for:
this it will be:
Postby baby_astons » Sun Aug 31, 2014 4:21 pm
just seen that there are a lot of issues missing, forgot uploading:
#54 #55 #56 #57 are the coresponding door parts for the other side, not necessary to post them
#58 and 59 are the rear lights including all cables etc
#60 battery tray and car jack
#61 boot floor
a few more later...
Postby baby_astons » Sun Aug 31, 2014 6:55 pm
next up is
#62 the spare wheel
#63 boot floor rubber inlay, soft and bendable, so it can be lifted to look at the spare wheel
#64 lhd side boot cover
the next 15 issues should be sent to me during the week - and I sincerely hope the postman will find me here in my holiday home in tuscany,
when those are in hand there'll be only 21 more issues and the alfa is prepared for build - including the new light metallic blue paintwork...
stay tuned...
Postby SDeath » Sat Sep 06, 2014 9:21 am
This looks like a really detailed model!!
Really nice!!
SDeath
Postby baby_astons » Sat Sep 06, 2014 11:31 pm
...it is sdeath, got the next 15 issues here in my holiday home in italy (my friend sent them directly to tuscany...)
btw, while on alfa, the next hachette is in hand, the first 4 issues of the giulia super in "carabinieri" outfit...
and don't dare to say, got issue #1 of the la ferrari today while visiting rome...
Postby baby_astons » Mon Nov 24, 2014 8:36 pm
hullo guys, 9 weeks to go and the little alfa is complete,
I see I need to post a big lot of parts for you to keep an eye on...
interestingly the italian hachette worked simply like a swiss watch, all issues spot on time - nothing EM can double with the nissan...
I think I started this before the gtr got a go and I suppose it won't catch up any more...
Postby baby_astons » Sat Jan 24, 2015 9:24 pm
well time flies by - yesterday was the day - 100 arrived :dance:
Postby baby_astons » Thu Mar 05, 2015 9:39 pm
...and parts now complete and in hand - I didn't go for the surprise supplemental 5 issues -
they consist of parts to build up a showcase for the model but wasn't worth 55€ plus shipment (which would have been expensive with the wood/alloy/glass/steel pieces...)
so i need to update the pictures at last and start painting the body parts blue...
Return to Other cars
