My T-800 Build
My T-800 Build
My T-800 Build
Postby corelki2005 » Mon Mar 04, 2019 11:19 am
Have today received the first two parts of the terminator.
Here are the pics of the parts
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Mar 04, 2019 11:20 am
The first part has been assembled
Nick
corelki2005
Re: My T-800 Build
Postby Mark » Mon Mar 04, 2019 12:06 pm
Good start Nick. I’ll make a new section for this one soon.
Re: My T-800 Build
Postby casper » Mon Mar 04, 2019 3:58 pm
Check for surface scratches Nick, I need another upper arm part :)
Re: My T-800 Build
Postby corelki2005 » Thu Mar 14, 2019 2:08 pm
Issue 3
You get
Battery box and mini pcb to check eye leds
The first finger
The first upper arm
pic of parts
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Thu Mar 14, 2019 2:09 pm
and after assembly
the eyes are quite bright
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed Mar 20, 2019 1:27 pm
Issue 4 has arrived
you get more parts for the upper arm
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed Mar 20, 2019 1:35 pm
Two pics of the upper arm assembled
For those that are doing this I have found it easier to a) insert parts 4-8 into parts 4-1 and 2-3 first the b) insert assembly 2-4/2-5 at right angles to the pic shown at step 13 (as per stage complete otherwise you may damage assembly 2-4/2-5) then bolting parts 4-1 and 2-3 together to pull them tightly together, finally removing the two screws and fitting the two pistons and refitting the two screws.
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed Mar 27, 2019 1:09 pm
Issue 5
you get parts for the lower jaw and the neck ball joint
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed Mar 27, 2019 1:10 pm
the completed assembly
Nick
corelki2005
Re: My T-800 Build
Postby casper » Mon Apr 01, 2019 6:10 am
Hi Nick :) looking good. what are the pistons made from
Re: My T-800 Build
Postby corelki2005 » Tue Apr 02, 2019 6:18 pm
Issue 6
The actual lower jaw, the lower teeth and the nose piece
I haven't done anything yet as there is not much to do.
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:23 pm
issue 7
more upper arm parts and head motor joint
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:25 pm
issue 8
Right wrist and thumb
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:27 pm
The wrist and thumb assembled and the fore finger from issue 3 added
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:28 pm
issue 9
the righthand head
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:29 pm
and with the two parts assembled
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:30 pm
issue 10
right hand middle finger plus the eye sockets
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:31 pm
the right hand with the thumb, fore and middle fingers attached
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Wed May 01, 2019 3:33 pm
a pic of the face with the eye sockets added plus the eyes lit up
Nick
corelki2005
Return to T800 Terminator
