My T-800 Build
Re: My T-800 Build
Re: My T-800 Build
Postby corelki2005 » Mon Jul 22, 2019 4:37 pm
The cranium was then fitted
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Jul 22, 2019 4:40 pm
And finally the faceplate was put in place
The shoulder pieces have been put in a tub until next time
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 1:51 pm
The next four issues have arrived and we get to assemble the right shoulder and connect the right hand to the lower arm and then add the upper arm
issue 23 first parts for the shoulder joint
issue 24 assembly of the first limb
issue 25 next set of parts for the shoulder
issue 26 connect the upper and lower arm
parts
Nick
corelki2005
Re: My T-800 Build
I also got the plasma rifle
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 1:53 pm
the first set of shoulder parts were assembled
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 1:54 pm
The final ball joint was attached to the wrist
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 1:57 pm
the lower arm was connected to the ball joints
the tendon springs were then threaded through the holes, connectors added and finally glued to the wrist (fiddly job)
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 1:58 pm
The shoulder joint was then assembled
Nick
corelki2005
Re: My T-800 Build
Postby corelki2005 » Mon Aug 19, 2019 2:04 pm
The upper and lower arm was then connected
Nick
corelki2005
Re: My T-800 Build
Postby casper » Thu Oct 17, 2019 1:35 pm
Hi nick :)
have you received issues 27-30, I only got 31-34 today and no letter with an explanation :think:
I see issue 29 is popular
https://www.ebay.co.uk/itm/Hachett-Part ... SwvDBdma4G
:shock: :o
https://www.ebay.co.uk/itm/Hachett-Part ... Sw9N9dmbGk
Re: My T-800 Build
Postby corelki2005 » Thu Oct 17, 2019 3:10 pm
Yes I have all issues up to issue 34, had to buy issue 27 off of ebay as it was out of stock :angry-banghead: and they dont know when it will be in stock, very poor, you would think us subscribers would get the issues first before the newsagents.
Will update my diary once I have edited the pics
Nick
corelki2005
Return to T800 Terminator
