TERMINATOR T-800 1/2 scale
Postby casper » Mon Apr 01, 2019 10:25 am
Time to start my Terminator diary :D
Issue one and two with free screwdriver set. Incidentally the screwdrivers fit nothing :laughing-rolling: and are mediocre quality but hey its free :D
http://www.jamescamerononline.com/endoskeleton.htm
Re: TERMINATOR T-800 1/2 scale
Postby casper » Mon Apr 01, 2019 10:53 am
Reposting some of my pics from the Terminator preview thread taken a couple of weeks ago, while listening to Stanley Clarke "school days"
Postby casper » Mon Apr 01, 2019 10:55 am
shame about the seam lines running down the cheekbone :roll:
Postby casper » Mon Apr 01, 2019 11:00 am
Issue two components
Teeth look very good and have good colour
Unfortunately the upper right arm component has a nasty scratch through to the copper coating so this one will have to be replaced asap
Postby casper » Mon Apr 01, 2019 11:04 am
Teeth have been carefully removed from the sprue and cleaned up.
Postby casper » Mon Apr 01, 2019 11:10 am
Upper Jaw fixed to the eye sockets using two 6mm screws and two 4mm screws (steps 2-3-4)
Postby casper » Mon Apr 01, 2019 11:13 am
Step 6 (fitting the teeth)
fiddley process but easy enough, don't use too much :superlglue:
Postby casper » Mon Apr 01, 2019 11:14 am
Issues one and two complete
casp :)
Postby casper » Mon Apr 01, 2019 11:21 am
Issue Three (Components for the right arm and first finger)
Postby casper » Mon Apr 01, 2019 11:53 am
Parts checked for scratches :think: :D All good
casp :)
Postby casper » Mon Apr 01, 2019 7:55 pm
Postby casper » Mon Apr 01, 2019 7:57 pm
:o Bright
Postby casper » Mon Apr 01, 2019 8:03 pm
simple and quick assembly.
You can reposition the shaft and tighten the screw later to try to hide the seam lines. :think:
The finger goes together really well and is bigger than I thought it would be.
Postby casper » Tue Apr 02, 2019 10:56 am
Issue four
Components for upper right arm
Postby casper » Wed Apr 03, 2019 11:31 am
Parts (right upper arm)
I won't assemble these parts until I receive a replacement for the scratched part.
Casp :)
Postby casper » Thu Apr 11, 2019 10:00 am
Issue Five
Lower jaw and neck (ball joint assembly)
Casp :)
Postby casper » Wed May 08, 2019 3:43 pm
Issue 6
Lower jaw, Lower teeth and bridge of the nose
Postby casper » Wed May 08, 2019 3:46 pm
Pearly whites look good but I don't like the mould lines
Postby casper » Wed May 08, 2019 3:48 pm
So I cleaned them up a bit with a wet sanding stick :D a couple are deep so didn't sand too much
Postby casper » Wed May 08, 2019 3:49 pm
And glued in place :D they look pretty good and the colours great
Return to T800 Terminator
