Now to take the "lower jaw" assembly from issue 5 and after adding the two brass bushes screw them together. The bushes allow a nice stiff joint for the lower jaw to move.
This was the most challenging assembly so far but still fairly easy. Each muscle spring has to be superglued in place before the small cover is screwed to the forearm
Morris Hachette Spitfire Mk1a partworks up to including issues 43-46 DeAgonstini Ford GT40 part work pack 8 Agora Models 427 AC Cobra pack 2 Posting some Lost in Space threads.. Posted a SSN Tigerfish from Ice Station Zebra
Right side added using two 6mm screws. Looks really good apart from the join down the centre of the neck but If not showing on the front it would have been down the sides.
The two screws go in from the rear of the assembly so to hold them in place a little bit of blue tac was used till the front section was added and the whole thing was turned over and screwed down.
