As you can see in the above photo I cut two ends off the plastic tube, when I tried it the first time it was over size and the finger was too loose. The chrome studs are push fit but a touch of superglue to the posts makes sure they stay put. left to dry
what's this opened the box containing issues 23-26 and found this box inside labeled 7th delivery gift. Not sure why its a gift as the T-800 comes with it anyway. The contents are nicely packaged in a velvety box and and look the great when assembled apart from the join right down the middle along the top. The barrel has a thread to screw into the main body and the trigger assembly and grip are metal, the trigger works so this could be for the lights and sound affects
Attach the head plate making sure the step sits in place both sides, tricky to get lined up but a little force pushes it all home. Then glue in the jaw bolt covers.
