Cyberdyne Systems Model 101
Postby Narayan » Sun May 19, 2019 10:51 pm
Greetings!
Welcome to my build of the T-800 Terminator.
I'll start off with the tools I am going to use for this build.
Firstly there is a screwdriver set the comes with the first instalment. This are large phillips head screwdrivers and a pair of tweezers.
I'm not sure how useful the screwdrivers will be due to the size but the tweezers should come in handy. That being the case I will be using this set.
A pill box will be used for storing spare screws.
Narayan
Re: Cyberdyne Systems Model 101
Postby Narayan » Sun May 19, 2019 10:55 pm
On to the build itself.
Stage 1 - The Eyes.
The red eye caps are inserted into the orbits.
Next LED diodes are fitted to the back of each eye.
These are then place into the inner eye sockets and held in pace by the eye socket brace.
No issues with stage 1 which is now complete.
Narayan
Postby casper » Tue May 21, 2019 7:13 am
Hi Graham :)
Great to see another T800 come off the production line, welcome.
Casp
Postby Narayan » Tue May 21, 2019 2:09 pm
Thanks Casper.
On to stage 2.
Starting off by fitting the upper jaw to the eye socket section completed in stage 1.
You need to be very careful with the screws provided. They come in one bag so not labelled. I have separated them out and keep them in a pill box.
Next are the teeth for the upper jaw.
These are quite large, too large I think. When the model is complete there's a chance the eye will be immediately drawn to them. I don't want that to be the case so I have trimmed them down a little. I might do some moew work on them at a later stage. In the meantime they have been attached to the upper jaw.
Finally for this stage I have attached two pieces of the upper right arm together.
Narayan
Postby casper » Sun May 26, 2019 9:44 am
I also thought the eyes looked a little too big but never thought of trimming them, will be interesting to see the difference as the build progresses.
Return to T800 Terminator
