1/200 Prinz Eugen (scratchbuild)
Re: 1/200 Prinz Eugen (scratchbuild)
Postby poulw » Sat May 23, 2015 2:29 pm
During the past several months I have been busy getting my house ready for sale come Sep/Oct.
This doesn't mean that The Prinz has been completely ignored. So ...
Time for an update
The hangar is almost finished (moveable part of the roof still needs to be constructed) and the second level of the rear superstructure is starting to looking good
37 Hangar1.jpg (103.14 KiB) Viewed 437 times
38 Hangar2.jpg (107.31 KiB) Viewed 437 times
41 Rear3.jpg (107.82 KiB) Viewed 437 times
42 Rear4.jpg (63.91 KiB) Viewed 437 times
Cheers .... Poul
Models:
Battleship Richelieu (scratchbuild 1/200)
Viking ship Oseberg (Billing Boats/part scratchbuild)
Projects:
Heavy cruiser Prinz Eugen (scratchbuild 1/200)
poulw
Postby Eric » Sat May 23, 2015 5:11 pm
Nice to see your still building Poul, superb work as always!
Postby Mark » Sat May 23, 2015 5:15 pm
She is looking superb Poul !
Postby poulw » Sun May 24, 2015 2:43 am
Thanks Eric and Mark for your comments. :D
Had a go at a couple of louvers last night after my post. They are made from 0.25mm styrene (which is almost see-through) and only 1mm wide.
My Lord, they are a bl**dy bitch to cut/position/align/glue without messing it all up.
43 Louvers.jpg (71.01 KiB) Viewed 437 times
Thankfully they normally look a lot better after painting ;)
The top of the level 2 superstructure is a bit too high on purpose so it can be sanded back to proper height when the next deck, about 1mm thick, is constructed (to fit on top between the walls).
Cheers .... Poul
Models:
Projects:
poulw
Postby poulw » Thu Jun 11, 2015 8:16 am
A small update:
Here are some pics of what I have completed since my last post:
The Hangar
Lower superstructure, front
44 Front lower superstructure.jpg (63.36 KiB) Viewed 437 times
Rear superstructure
45 Rear superstructure 1.jpg (92.56 KiB) Viewed 437 times
I hope you enjoy it as much as I do :dance:
Cheers .... Poul
Models:
Projects:
poulw
Postby chill » Thu Jun 11, 2015 8:26 am
Stunning work as always
Postby Mark » Thu Jun 11, 2015 9:19 am
Always look forward to your update Poul. Like Chill says, your work is stunning !
Postby poulw » Fri Jun 19, 2015 1:36 am
The top level of the rear superstructure under construction
46 Rear superstructure construction.jpg (101.75 KiB) Viewed 437 times
It is starting to getting a bit complicated with the slight differences in structure/colour of the timber decks with another type added.
Until now 3 different types of timber decks, but so far so good.
Cheers .... Poul
Models:
Projects:
poulw
Postby Mark » Fri Jun 19, 2015 5:41 am
Nice to see the match coming out to play again !
Postby steve131 » Fri Jun 19, 2015 7:54 am
Very good ,match good size marker
Postby poulw » Thu Mar 17, 2016 6:05 am
Hello again,
After 7 months off working on my house (it really needed it) I am now back into modelling mode and continuing on the rear superstructure.
It took a while to figure out how to construct the signals platform (holding the main mast) that sits above the hangar, but I think I cracked it.
Here is a pic of the rear superstructure (at present) loosely dry-fitted
47 Rear superstructure 2.jpg (124.43 KiB) Viewed 437 times
Status: Total 3855 parts so far
Cheers .... Poul
Models:
Projects:
poulw
Postby Mark » Thu Mar 17, 2016 6:11 am
Nice to see you back Poul.
Great work as always. I see you're buying those giant matches again :lol:
Postby poulw » Fri Apr 29, 2016 3:27 am
Been a busy month since my last post - and the front superstructure is now growing.
Three points need to be absolutely aligned:
the 2 large rangefinders at the back (with domes and not shown) and the front wall, which goes all the way up the three levels. The front wall and the swing-out bridges will be next before starting on the tower itself.
Here are some dry-fitted pics of the progress. The structure looks a bit clumsy on the pics, but the reason is the masking tape between the levels and over some of the planked decks. It will look much nicer with the masking tape removed.
Side on:
48 Front lwr levels 1.jpg (90.49 KiB) Viewed 437 times
Angle from the front:
49 Front lwr levels 2.jpg (98.94 KiB) Viewed 437 times
Close-up of the combat centre and front rangefinder:
50 Front combat centre.jpg (105.37 KiB) Viewed 437 times
Cheers .... Poul
Models:
Projects:
poulw
Postby casper » Fri Apr 29, 2016 5:15 am
amazing attention to detail
looking amazing poulw :clap: :clap: :)
Postby poulw » Wed Jun 22, 2016 10:12 am
Growing steadily :dance:
Front superstructure almost ready except for some fences on top and four range finders
51 Front superstructure.jpg (95.45 KiB) Viewed 437 times
The tower only needs some platforms and the wheel house on the Admiral's bridge
52 Tower wo platforms.jpg (80.44 KiB) Viewed 437 times
Cheers .... Poul
Models:
Projects:
poulw
Postby Mark » Thu Jun 23, 2016 1:21 am
Stunning Poul. Always look forward to your updates :D
Postby steve131 » Thu Jun 23, 2016 7:47 am
Great work :clap:
Postby number1 » Thu Jun 23, 2016 6:39 pm
Excellent :clap: :clap: :clap:
Postby builder » Wed May 03, 2017 2:17 pm
Hi Poul,
Where did your Prinz go?
On the shipyard or ......?
builder
Postby builder76 » Wed May 03, 2017 5:57 pm
Very interesting build Poul. Great attention to detail.
Enjoying the diary & information. :D
John
builder76
