1/700 scale sharnhorst
Postby number1 » Sun Apr 27, 2014 10:41 pm
This is my first attempt at using P.E and a wooden deck in this scale, in fact this is only the second ship I've ever tried to build, so will it ever get finished or end up in the bin?
Here's a pic of the PE, Im using Eduards and Lionroar for the railings, reason for using the Lionroar railings is that they have a rail running along the bottom rather than Eduards where you have to stick individual stanchions to the deck :superlglue:
Havent taken a pic of the lionroar railings yet :whistle:
Re: 1/700 scale sharnhorst
Postby number1 » Sun Apr 27, 2014 10:44 pm
This is the deck I'm using, it's by mk1 design
Postby number1 » Sun Apr 27, 2014 10:48 pm
I've started off replacing moulded on ladders with PE ones
Almost forgot the scale oxo cube :lol:
Postby number1 » Sun Apr 27, 2014 10:54 pm
Funnel attached to replacement deck piece from mk1 design, as well as the wood deck they also include this brass deck plus a couple of ships name plates for the bows, I had a slight gap at the front, filled in with pva glue.
Postby number1 » Sun Apr 27, 2014 11:06 pm
Part of the bridge before anything added, I've cut a small opening in the rear of the "guard rail" as on the real ship to enable the crew access to the mast.
same part with doors and deck fitted also a bit of railing at the rear where I had cut the access way to the mast, this has since come off and is waiting to be replaced :angry-banghead:
Postby Mark » Mon Apr 28, 2014 1:04 am
Oh, nano-engineering ! You're a brave man attempting a 1/700 ship with etched details :clap:
Looking good so far :clap:
Postby number1 » Mon Apr 28, 2014 6:15 am
Thanks Mark, first time for everything, this could go either way, in the bin and put down to experience or it might even get finished :laughing-rolling:
I've got a slightly bigger one waiting on the slipway, its the Dragon 1/350 sharnhorst, also with extra PE, this time white ensigns frets and a replacement deck from artwox, lets see how I get on with this one first :handgestures-thumbupleft:
