1/350 IJN Yamato (Tamiya New Tool)
Re: 1/350 IJN Yamato (Tamiya New Tool)
Postby davetwin » Thu Oct 02, 2014 9:34 pm
Its been a little while since I have had a chance to spend anytime on this sadly, family and home life seem to just keep getting in the way.
The last few days though I have finished the open 12.7cm guns, the level of cocentration on these due to the parts being tiny and fiddly made it quite tiring. I also done some very small detail painting on various parts, when zooming in with macro they looka bit messy but really dont look that bad in person, damn that macro zoom.
davetwin
Postby davetwin » Wed Oct 08, 2014 11:29 am
Still slow going with this at the moment, doing bits here and there time permitting.
One tripple 25mm complete
4 complete, some straightening to do
20 more to go
davetwin
Postby davetwin » Wed Oct 08, 2014 2:43 pm
Several hours and countless drops later they are all done
This is the back of the turret
davetwin
Postby Mark » Wed Oct 08, 2014 4:09 pm
Oh, tedious !!!!!!
Postby davetwin » Wed Oct 08, 2014 4:23 pm
Oh it was, I still have the open triple 25mm and signle 25mm to go, might do something else and come back to them :D
davetwin
When I last built models many moons ago I never really managed to get the hang of water slide decals.
So after I finished the guns I dug out my test kit and started playing with the declas, a couple ruined but got the hang of it so started on one of the planes. The black cockpit was very tricky as had to fold over the cockpit.
Picture is work in progress which is why it is still wearing a gloss coat, have put aside now to let the microsol dry out will then finish the rest tomorrow
davetwin
Postby davetwin » Thu Oct 09, 2014 11:16 am
2 x E13A "Jake" aircraft all decalled up, just need to leave over night to allow the setting agent to completely dry out then add the final matt varnish
One to give some sort of scale
davetwin
Postby davetwin » Thu Oct 09, 2014 8:59 pm
The last couple of days has been one of the times where I get a lot time to spend modelling 8-)
This evening I primed up the 12.7mm guns and made a start on the triple 25mm AA gun, only one done so far, was very fiddly though and only another 29 to go :o This might take a while
The Pontos set does have replacement turned brass barrels for these but I have decided to not to use these as I think the plastic ones look pretty good and I didnt want to torture myself replacing them all
davetwin
Postby number1 » Fri Oct 10, 2014 1:49 am
Hi Dave, your doing an incredible job on the yamato. K awarded,
(PS, the preferred unit of scale is the oxo cube ;))
Postby davetwin » Fri Oct 10, 2014 8:21 pm
number1 wrote:Hi Dave, your doing an incredible job on the yamato. K awarded,
Thanks number1
Will get an oxo cube when I next go shopping as dont have any in the house
davetwin
Postby davetwin » Fri Oct 10, 2014 8:22 pm
Assembled one of the Mitsubishi aircrat with some more intricate PE. Only one as the carpet monster had the wing struts away for the second one
All the bits for the remainig 29 triple AA cut from the srpues & frets ready to start the slow clean up before assembly
davetwin
Postby steve131 » Fri Oct 10, 2014 8:51 pm
Very nice thinking of getting Tamiya Bismarck K awarded. :clap:
Postby davetwin » Fri Oct 17, 2014 9:12 pm
After the long and slow process of cleaning up all the parts in the previous post I have now started the slow task of assembling them.
First 10 complete, another 20 to go
Using our standard method of scale
davetwin
Postby davetwin » Sat Oct 18, 2014 2:18 pm
I have spent all morning today working on the triple 25mm and finally got them all finished and primed
All 30 ready for primer :D
Usual close up macro zoom
davetwin
Postby Mark » Sat Oct 18, 2014 2:34 pm
Tedious !!! Have a K for patience :D
Postby davetwin » Wed Oct 22, 2014 10:38 pm
Thanks Mark
12.7cm DP guns sprayed, thinking of adding a wash, they arent as ghostly looking in the flesh its just the overhead light
30 open triple 25mm guns sprayed and then hand painted model air metallic black
Finally got the Matt coat on the planes, they look so much better, only thing now is I am thinking of doing a wash so will need to gloss them again
davetwin
Postby davetwin » Fri Oct 24, 2014 10:53 pm
I did another picture of the 25mm's as the light wasnt too good on the other one, Oxo cube for scale in picture above, you get 9 of these on the top of a cube
davetwin
Postby davetwin » Fri Nov 21, 2014 11:54 am
Well is beena while since my last update due to a number of reasons getting in the way and restricting my model time. Things like work, family time, being too cold in my garage where I model, I have not long owned the house so not had the chance yet to insulate it.
Here is a small update on what I have done since the last one, one thing not shown is the main number 1 turret now primed ready for paint.
Also no picture of the Mitsubishi aircraft that is now painted, gloss coated and almost finished decalling.
Shielded 25mm guns painted, barrels painted and everything sealed with matt varnish
Number 2 secondary turret finshed with the addition of ladders and railings then primed ready for paint
Somoke stack top sprayed black, this was really difficult due to all those pipes and etch, used blue tac to mask up, its not perfect but im happy with it, also gloss coat added ready for declas
Flight deck sticker added, initially I though this was a decal so I added a gloss coat, will seal with matt varnish
Chain painted as wasnt happy with the Kure grey I had painted it, also platform added
A few small details added near the break water
Dry transfer
Dry transfers on both sides, I know the join between the hull pars and rescored panel lines are not the neatest but bear in mind this is taken in macro mode with full zoom, in he flesh I am quite happy with my effort
And finally open 25mm and main gun barrels final matt coat applied
davetwin
Postby Mark » Sat Nov 22, 2014 3:05 am
Don't you just hate it when life interferes with modelling !!! Well done for getting the funnel as neat as you did. It looks a real pain !! I think I would have been tempted to use a brush !!
Postby davetwin » Wed Dec 03, 2014 10:17 pm
Time for another update on where I am with this beast.
I have applied the decals to the smoke stack but no pictures yet until matt coat applied.
'Pete' aircraft finsihed
Number 2 & 3 primary turrets 'brassed up' sand bags added, just need to prime now to get to where I am with number 1 turret
davetwin
