Gatling Gun 1874
Gatling Gun 1874
Gatling Gun 1874
Postby Mustang » Mon May 06, 2019 11:07 am
So while I wait for the oils on the Mossie to dry, I thought Id do something small a quick.
But instead of going though my ever growing stash, I found this on eBay for £18 inc p&p great price as Ive seen them going for £50+
1/32 scale Gatling Gun by Verlinden.
Re: Gatling Gun 1874
Postby Mustang » Mon May 06, 2019 11:08 am
Parts list
Postby Mustang » Mon May 06, 2019 11:09 am
The instructions
Postby Mustang » Mon May 06, 2019 11:11 am
The parts, as this was second had there was a piece missing number 12 Gun barrel elevator
Postby Mustang » Mon May 06, 2019 11:14 am
First up I need to remove the axle as it was fitted the wrong way round.
So I managed to prise them apart with out damage.
Then cleaned and refitted the correct way round.
Postby Mustang » Mon May 06, 2019 11:15 am
Stage one finished
The underside view
And the top view, I also redone the grab handles.
Postby Mustang » Mon May 06, 2019 11:19 am
Next I need to make a new Gun elevator pin, I could have just added a piece of brass rod.
But I decided to add the screw detail to it.
I also left a small piece of rod at the end where it will meet the barrel housing.
Postby Mustang » Mon May 06, 2019 11:20 am
Look about right.
Postby Mustang » Mon May 06, 2019 11:22 am
The rear of the barrel chamber was missing a small detail, so I added a small piece of plastic.
Postby Mustang » Mon May 06, 2019 11:24 am
Managed to break this piece .
But managed to repair it by adding a piece of plasticard which you can just see in the above photo
Postby Mustang » Mon May 06, 2019 11:28 am
This is what is supplied to build the barrels.
Instead Ive used brass rods.
Added the centre one to get the front end fitted
Then added two more for support.
The others will be added once its all painted.
Postby Mustang » Mon May 06, 2019 11:29 am
Dry run.
Postby Mustang » Mon May 06, 2019 11:33 am
Final part of the build is the wheels, this is the jig to build them. Took me awhile to remove all the (I must not use naughty words) around the outside just so I could get the rims to fit.
Hubs and spokes.
Fitting the parts.
There was small holes in the rims for where the spokes went, I gentle drilled these a bit bigger so the spokes would fit in them.
Postby Mustang » Mon May 06, 2019 11:35 am
The finished wheel view from the rear.
The front view.
Dry fit.
Postby Mustang » Mon May 06, 2019 11:37 am
More once I've started the painting.
Postby Mark » Mon May 06, 2019 1:49 pm
Nice score, and not a bad price, even started and a bit missing. I can’t work out why they didn’t cast the wheel spokes and rims in a ne piece though.
Postby Mustang » Mon May 06, 2019 6:41 pm
So had a go at the wheels, base coat and and then sealed.
The left one is the base coat and the right is the one stained up.
Postby Mustang » Mon May 06, 2019 6:43 pm
They dont look to bad, never liked painting wood hence the decals on the Mossie.
Postby Mustang » Mon May 06, 2019 6:48 pm
Mark wrote:Nice score, and not a bad price, even started and a bit missing. I can’t work out why they didn’t cast the wheel spokes and rims in a ne piece though.
Thanks for dropping by Mark
Postby royjess » Mon May 06, 2019 7:32 pm
Great start, I'm watching with interest. I've my pop corn ready :)
