SUPERLEGGERA STICKERS ON THE BONNET
GE Fabbri's Aston Martin DB5 from Goldfinger. This is going to be a big and impressive model - nearly 2 feet long and weighing 20 lb with lots of detail including working lights, horn, ejector seat, etc.
Postby Auric Goldfinger » Tue Apr 04, 2017 8:50 pm
Hi I have a problem with the Superleggera Stickers on the Bonnet of my 1-8 Aston Martin DB5 They Fell off as I was Dusting the Model they are so Flimsy and Badly Made can anyone offer me an alternative is there anything superleggera That Small even photo etched that I can use as a Replacement any info will be Appreciated cheers Auric Gold Finger
Auric Goldfinger
Re: SUPERLEGGERA STICKERS ON THE BONNET
Postby chill » Tue Apr 04, 2017 8:59 pm
You really aren't having much luck are you .
Postby Auric Goldfinger » Wed Apr 05, 2017 12:13 am
No Luck at all if its not one thing its another that's they way things are but I wont give up Auric Gold Finger
Auric Goldfinger
Postby chill » Wed Apr 05, 2017 8:26 am
Well maybe i can suggest you invest and get a display case and then the model wont get dusty and you wont have to dust it at all incurring damage to the model..
I believe many builders have done that.
Postby Mark » Fri Apr 07, 2017 7:36 am
Just glue it back on with superglue !
Return to James Bond's DB5
