1/16th scale Vintage Prop
Postby Mike B » Fri Dec 30, 2011 1:12 pm
Here is another project made from card - 36 layers!
The nuts were made from eyelets left over from TITANIC, flats filed on them and then a piece of brass rod glued in them.
Unbelievable what you can do with paper! :o
For anyone interested in how it's done, http://www.papermodelers.com/forum/desi ... #post35343
Mike B
Re: 1/16th scale Vintage Prop
Postby Mark » Fri Dec 30, 2011 2:19 pm
Very impressive Mike. Nice smooth finish. Did you sand it and recolour the edges ?
Postby casper » Fri Dec 30, 2011 5:17 pm
that looks amazing Mike.
you would not know it was made of paper. stunning job and great tutorial.
Postby Mike B » Fri Dec 30, 2011 11:05 pm
Mark wrote:Very impressive Mike. Nice smooth finish. Did you sand it and recolour the edges ?
I used card that was coloured right through (got it from a craft shop) - Buff coloured card and Brown coloured card as in the instructions in the link. Only a very light sanding was needed when it came out of the jig. I did not use varnish as used in the tutorial but sanding sealer. In total, I used about 5-6 coats, sanding down between coats until I got the glossy finish that you see. The tutorial was 100% and it came out just as it said! :dance:
Mike B
Postby morrigan » Mon Jan 02, 2012 9:07 pm
My goodness - thats card? Most impressive Mike.
Return to The Model Show Case
