1/100 scale Sperrbrecher. Mine clearing Vessel
Postby maximus2012 » Sat Aug 11, 2012 8:14 pm
maximus2012
Re: 1/100 scale Sperrbrecher. Mine clearing Vessel
Postby maximus2012 » Sat Aug 11, 2012 8:15 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:16 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:17 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:18 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:19 pm
maximus2012
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:20 pm
maximus2012
Postby Eric » Sat Aug 11, 2012 8:21 pm
Wow!
Superb Model Max, is it scratch built?
Just to let you know, we will shortly move this thread to the "Ships" section so we can keep the Hood section to Hood related threads only.
Please please please show more models if you have them, you are an excellend model-maker! :clap:
Postby maximus2012 » Sat Aug 11, 2012 8:21 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:23 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:24 pm
maximus2012
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:25 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:26 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:27 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:28 pm
maximus2012
Postby maximus2012 » Sat Aug 11, 2012 8:39 pm
Eric wrote:Wow!
Hi, would be nice if we had a build model section. It is built after a very small 3 inch long picture. The use those ships around the channel port and the french ports to detect acusitic and magnetic mines, foreship was designed to break of when been hit by a mine with failed to be neutralized, the just welded another bit back on to the ship. The Hull I picked up at show years ago and the fittings are from different manufacturers from england and the continent. It was designed to be a working model, had Rudder/Servo fitted and it is working ok. Also got a propshaft fitted, but the decks are fixed down, the could be carefully removed I guess, the model was to big and heavy for me to launch, ( 2 man job) and it would not fit in to the car. Now it is gatehering dust in a spareroom. Took me 6 month to build 5 years ago. No I want to get writ with it, need the space. It is about 5 foot plus long I think, you see the comparison of the 1/200 scale Hood next to it 1/100 scale. Glad you like it.Its is a multymedia project, Grp, ply, plastycard,lithoplate and brass tubing for the masts and derricks. Fittings are white metal and resin.
maximus2012
Postby Eric » Sun Aug 12, 2012 3:01 pm
Topic moved.
I have aspirations to scratch build my own model. I have 1/250 scale plans for HMS Queen Mary, a WWI Battlecruiser.
I may be tempted to have a bash if I can get a little hobby bandsaw to shape the hull ribs. :think:
Postby Mark » Sun Aug 12, 2012 3:32 pm
We do have a section for buit models. It's called the Model Show Case. This is a very nice model indeed. Definitely one to be proud of !
Return to The Model Show Case
