SHERMAN M4A3 105MM WINTER 44(REPOST)
Postby builder76 » Thu Apr 13, 2017 6:25 pm
Hi fellow modellers,
I would like to submit my winter 44 Sherman for your comments/advice.
This was my 2nd venture into winter dioramas.
I hope my posting turns out ok. :!:
Regards
John
PZKFW 1V G 001.jpg (499.77 KiB) Viewed 840 times
PZKFW 1V G 002.jpg (460.33 KiB) Viewed 840 times
PZKFW 1V G 003.jpg (440.62 KiB) Viewed 840 times
PZKFW 1V G 004.jpg (455.87 KiB) Viewed 840 times
PZKFW 1V G 005.jpg (155.97 KiB) Viewed 840 times
PZKFW 1V G 007.jpg (448.25 KiB) Viewed 840 times
PZKFW 1V G 008.jpg (491.12 KiB) Viewed 840 times
PZKFW 1V G 009.jpg (398.04 KiB) Viewed 840 times
PZKFW 1V G 011.jpg (161.27 KiB) Viewed 840 times
builder76
Re: SHERMAN M4A3 105MM WINTER 44
Postby steve131 » Thu Apr 13, 2017 8:09 pm
Great work ,did you use the Tamiya model :?:
Postby Mark » Fri Apr 14, 2017 1:56 pm
That's brilliant John, very realistic. What did you use for the snow ?
Postby wingnut » Fri Apr 14, 2017 4:05 pm
Hello John, if that was an example of my work I would be very pleased with it :clap:
Return to The Model Show Case
