SOVIET 57MM ANTI-TANK CREW ,BREWING UP
Postby builder76 » Mon Sep 10, 2018 5:05 pm
Hi Guys,
I thought for change I would do a dio without an AFV in it.
Saw this Mini Art kit Soviet 57mm anti-tank +crew on line , continuing my Soviet theme(this will be my penultimate Soviet dio).
The gun turned out to be a real pig to build, small intricate pieces some requiring careful alignment, some also ended up being rescued from the dreaded carpet monster. Only grit determination saved the day. I also learnt a few new expletives.
However when I finished building & displayed it ,the gun/crew looked a little bare all alone on the dio.
So after a bit more research I added an Eastern Express Army Truck
ZiS -5V kit as an ammo truck, plus a camouflage ammunition dump. tree & wall. That seemed to fill out the dio and give it a must better all round perspective.
I am personally pleased with the final finished overall build, turned out better than I initially envisaged.
Comments /criticisms as usual, always appreciated.
John
SOV ART 2.jpg (357.08 KiB) Viewed 1262 times
SOV ART 3.jpg (410.91 KiB) Viewed 1262 times
SOV ART 4.jpg (316.8 KiB) Viewed 1262 times
SOV ART 5.jpg (477.05 KiB) Viewed 1262 times
SOV ART 6.jpg (367.48 KiB) Viewed 1262 times
SOV ART 7.jpg (410.35 KiB) Viewed 1262 times
SOV ART 8.jpg (372.76 KiB) Viewed 1262 times
builder76
Re: SOVIET 57MM ANTI-TANK CREW ,BREWING UP
Postby wingnut2 » Mon Sep 10, 2018 5:17 pm
Amazing work John :clap: may be there's hope for me yet :o
Postby Mark » Mon Sep 10, 2018 5:33 pm
Stunning work John. Your ground work (mud, grass, etc.) is incredible.
Postby royjess » Mon Sep 10, 2018 9:58 pm
Live all the above said, amazing work, well done :clap:
Return to The Model Show Case
