Possible disruption
The place for idle chatter
Possible disruption
Possible disruption
Postby Mark » Mon Sep 17, 2018 6:33 pm
Hi Folks, just to give you a heads up. My hosting company is messing about again. I shall be moving my web sites to a different host, but in the meantime, there may be some disruption to services. Don't worry, if I'm off line for a while. I'll be back!!
By the way, if you ever come across a company called TSO Host, run a mile. They are absolutely..... naughty word censor melts......
Re: Possible disruption
Postby casper » Mon Sep 17, 2018 6:45 pm
Thanks for the heads up Mark :)
Postby booth » Mon Sep 17, 2018 8:51 pm
Yes, thanks!
booth
Postby Morris » Mon Sep 17, 2018 9:29 pm
Thanks Mark, good luck
Hachette Spitfire Mk1a partworks up to including issues 19-21
DeAgonstini Ford GT40 part work pack 3
Postby snapdragon » Mon Sep 17, 2018 11:33 pm
Good luck!
You want me to arrange any accidents?
Postby Morris » Tue Sep 18, 2018 9:55 am
:laughing-rolling:
Postby royjess » Tue Sep 18, 2018 10:45 am
Thanks for the Heads up, let hope that the new hosting company do a better job and the transition is smooth
Postby wingnut2 » Tue Sep 18, 2018 4:19 pm
Mark wrote:Hi Folks, just to give you a heads up. My hosting company is messing about again. I shall be moving my web sites to a different host, but in the meantime, there may be some disruption to services. Don't worry, if I'm off line for a while. I'll be back!!
:text-goodpost: Thanks for the heads up Mark, see you on the other side ;)
Postby R2D2 » Tue Sep 18, 2018 7:49 pm
Good luck Mark from r2d2. I'm presuming this is because they messed up the photo files. As you said lets hope they do a better job. I know you've tried your hardest so here's hoping!
Postby builder76 » Sat Sep 22, 2018 6:25 pm
Thanks for the warning Mark. :D ;)
Hope all goes ok.
John
builder76
Return to The Mess Room
